I know many of you have tower lights so I'm wondering if they use relays as they do for autos? I'm getting ready to help a bud wire some up to his Sanger. Do they series wire all the lights together to larger gauge wire for the +,- and ground?
Tower lights / using relays?
in essence a normal auto install without taping the lighting system of a car. I wonder if a heavier gauge wire could handle the load of four lights to the relay without cooking it? I've checked a couple of online install instructions from different tower mfgrs and they only show three wires from the bank of lights to the power source, so that's how they got to be doing it."Call me anything you want ... Just don't call me NOBODY!
Just pick your wire gauge to the current that will be going through it.....also check the amp rating on the relay. I think you will be fine. 12V are usually 60-90 amps....more than your altenator can put out. As far as wire goes, 16AWG will handle 25amps with no sweat.
Amps = Watts/Volts
So if you have 4 50W bulbs.....50/12= 4.2Amps......
16 gauge wire, and a common auto relay will do you fine!http://www.wakeboatworld.com
[]) [] []V[] [])
http://www.powerstream.com/Wire_Size.htm
AWG Diam amps
16 0.0508 22
says 22 but it is not giving the 30% measurement. Usually in electroinics you pad your parts 30-50% for fluctuation and spikes.
i guess a proper chart would be to use this one
http://www.the12volt.com/info/recwirsz.asp
regardless you would have to have 4 50 watt lights to get close to metling 16 gauge wire. You will probably have a 10A cb, on some low wattage leds lamps, or similar I hope.Last edited by spharis; 11-17-2006, 10:27 PM.http://www.wakeboatworld.com
[]) [] []V[] [])
