I have a 2008 tige 22ve and the bilge/nav lights/blower/ballast just stopped working after doing an oil change and taking the batteries out to charge. Everything seems to be connected properly, cleaned the terminals and connections, switched the batteries back and forth, checked all the fuses I could see and wiggled all the wires but can’t seem to get it working again. Boat starts and runs fine. Radio works. Everything worked before I disconnected the batteries so it feels like I’m just missing something stupid but I can’t figure it out. Help.
Blower/bilge/nav lights/ballast not working
Look around the batteries for a flip type Bussman breaker. May have gotten bumped and its open.
https://www.zoro.com/bussmann-automo...RoCfy0QAvD_BwE
^^will look something like that.
Sounds more to me like a missing ground if those are the only functions not working.
Do you have power at any of these functions? Blower may be the easiest one to tell. Probe the positive side and run your ground lead to the battery. This will tell us if its a ground issue or a power issue.Oh Yeah!
