No info to gauges
    No info to gauges
    2012 RZ2
    Gauges have power but not communicating with engine...no fuel level, RPM, speed. Temp and depth ok. Stereo ok.
    I’ve checked easily visible wiring under dash and around engine.
    Any suggestions?
    Can hi/can low connection is severed would be my guess. Check the white 12 pin under the dash. Look for the blue and white twisted pair of wires. Check voltage from each one to ground. They should be 1.5v to 3v each.
    Oh Yeah!
