Taps Under Dash Relay to single white throttle wire connections
    Hi All,
    Well as I was trying to address my throttle cable issue I have somehow managed to pull the three wires that run from the taps switch on the throttle lever (out of a single white wire) free from the connectors at the relay. Here's a pic taken on my back looking up at the relay under the dash. You can see the three thin wires that exit from the single white lever wire in the foreground and wires exiting the relay behind them.
    Before I just do red to red black to black etc can someone confirm which connect to which. I just want to be sure.
    Thanks in advance.
    2002 21iR (mid year boat came with 03 hull)
    Experience - Something you get right after you needed it.
    It should be black to black/white, red to red/white and white to white. Switch gives momentary ground to the relay box.
    Oh Yeah!
      Awesome, thanks so much for the confirmation!!!!!!
