Blower & Bilge pump stopped functioning (we think) at the same time. After reading some of the blogs - which were very useful, thank you - we went to the manual switches under the helm, and these switches turned on the blower and bilge pump independently and successfully. However, as before, the TT controls would not engage either device, even though the TT panel showed "green" for each device when tapped or turned on.
Again, we went back to the blogs, and then inspected the two fuses in the fuse box under the helm. Two failed fuses - bilge & blower. Replaced both failed fuses with 10 amp fuses. Success - the TT would now control both bilge and blower, with the blower staying on the designed 4 minute delay.
We were not sure if the bilge pump was an automatic design to come on when we were on the water if we needed it to do so. Decided to test it with a garden hose while trailered at home. With the drain plug installed, and the blower turned on by the TT control, we filled the bilge with water until the level reached the air intake at the bottom of the blower module and the blower began "struggling" as it handled both air and water. We turned on the bilge pump with the TT control, pulled the drain plug, left the blower on and drained the bilge. The blower sound returned to normal when the water level dropped, and the blower shut off automatically - we assumed??? We are now not sure that the blower timed out, or stopped for another reason - please read on.
We were not sure if we may have damaged the blower when the water level was too high, and we let it sit overnight and then tried the blower. It would not start with either the manual switch under the helm, or with the TT control. The bilge pump will start fine, with both the manual switch and with TT control. We then removed the blower assembly (4 hour job) and bench tested the blower with a spare 12 v battery. Blower works fined. Re-installed blower, to again find no success in having it start when installed in it's normal circuitry. It will not run with either the TT control, or the manual toggle switch under the helm, and all fuses under the helm have been doubled checked many times.
We are out of ideas, and need suggestions please.
