2006 tige 24ve Taps switch
    The taps in my 2006 tige 24ve worked about 2 weekend ago but when I took it out this last weekend it wouldn't move up or down. I still have voltage to the center (red) wire at the switch. Is there any way to test that the switch is still good? Also, is there any way to bypass the switch so that I could at least put the taps to 7 for Wakeboarding?
    Sounds like your oil is low or is due for a change in your Taps system. Check the fluid level the resi. is behind the rear panel on the starboard side can miss it.
      Post Some Pics the 24VE is such a great boat!!!!
