My taps was working great until a couple days ago on my 2008 RZ2. Taps will come down, from 8-1, but won't go up, 1-8. I could hear the pump kick in for the down part but nothing for the up part. By chance I tapped the throttle near the switch and it would work but since has stopped. Opened up the throttle lever and found many points in the 3 wires that the covering had worn thru and even where the blue wire was completely ripped in two. Under my dash their is extra wire zip tied so I pulled more wire thru the throttle lever to get rid of the damaged section and cut off the switch. While heating up the solder to remove the old damaged wires I must have cooked the switch. It doesn't click anymore when pushing the button. Currently my taps plate looks basically in line with the bottom of the hull, Iike an extension of it not pointed up towards the swim platform. Where can I get a switch?
Thanks in advance.
Thanks in advance.
