While I was draining the block on my 2011 Tige RZ2, I discovered a loose cable. It was located on the starboard side of the engine, and I had to move it out of the way to get to the block drain plug. It runs the same general route as the cable connected to the alternator/stator. Maybe it is supposed to be this way, but doesn't seem to be correct. Any ideas what this is for?
Loose Cable Found
Tigé Jedi- Jul 2010
- 4274
- TN USA
Lots of extra connectors on most engine harnesses, for various options you may not have. Most likely very normal.
On my engine I found an entire extra cable. Very heavy gauge, perhaps 2/0, with battery-style lugs on both ends. Literally sitting loose across the engine block, both ends free, connected to nothing at all. I just pulled it out and stored it.
It would help if you could provide a photo, so we could see exactly where it is and what kind of connector is on the end.
Tigé Jedi- Jul 2010
- 4274
- TN USA
I presume the engine comes from the manufacturer with a "standard harness assembly" and the boat builder uses the parts they need for the components and accessories on that particular boat.
On mine, I removed the stray cable because I don't like loose pieces rattling around back there with spinning belts and pulleys!
