2013 RZ2, had a leak at my driveshaft which I've now fixed, but not until after taking on a lot of water and almost sinking the boat last week (killed the motor and barely got the boat out of the water in time). Wanted to see if any of these were easy fixes before having to take the boat into the dealer.
Issues:
1. Luckily the motor started up again once I got the water out. however it makes a loud click sound now and doesn't seem to start as easily as before?
2. Bilge pump doesn't work anymore (part of the reason why I almost flooded the boat). Found the inline fuse and it seems fine. Anything else that could have shorted out from being under water?
3. Factory underwater lights no longer work. When I push the button on the touchscreen panel the button doesn't light up either.
4. Factory Bluetooth no longer works. The button on the touchscreen is grayed out now.
5. The "Gauges" button on the touchscreen no longer works.
Any help would be appreciated!
Issues:
