So a bit of background, originally my 4 in 1 was having issues, the voltage was wrong, as was fuel. this got annoying! so I tried to fix it but after carefully taking it apart and trying to sort out the needles got fed up and gave in, basically the plastic had split that goes over the shaft meaning it would slip and therefore never be accurate.
Now conveniently my job is an electronics engineer so i set about making a new gauge :-) unfortunately traditional LCD screens and sunlight just don't get along, well that is if you want to be able to read them! after a lot of research I came across a special type of LCD from Sharp that requires no back light and the brighter it is outside the better, its only black and white but the contrast ratio is awesome.
I then soon realised that to make this thing look nice i needed to significantly improve my CAD and CAM skills, conveniently I have access to a small CNC milling machine so other than my time and materials it had little expenditure.
I am using an ARM processor to drive the screen, and have GPS on the board, I'm using the existing senders for the readings and conversion curves i found.
the plastic I used is 20mm PVC and perspex for the lense.
So we all love photos...
CAD work.
CAD work.
