Increase amps on circuit breaker
    I increased the size of my factory ballast pumps on my 08 22Ve. Now i need to increase the amps on the circuit board. Does anyone know how to do that?
    Swap the break out for one the a higher amperage. However, keep in mind that the size of the breaker should not exceed the capacity of the cabling. Nor should the pump's current draw. What size (brand/model) pumps did you go to?
