My ballast keeps quitting, on initial fill it works fine, then when I go to switch sides it won't work, the tige touch says the one side is filling and the opposite is draining but the pumps don't turn on. After messing around with miscellaneous things like turning the battery switch off/on resetting viper or tapping the windshield twice and the tower 3 times they usually suddenly start to work again. Is there relays inside the fuse panel for these pumps? This is very annoying.
Ballast stops working intermittently
Originally posted by dilpickle View PostI have had twice where one of the rear pumps would not empty & found the fuse was making poor contact. I removed the fuse, wiped the terminals & then reinserted the fuse-voila, pump immediately came on. This was on a different pump each time.
