Fuse box location
    Fuse box location
    I own a 1999 2100i and my bilge, horn and blower are not working. Being stubborn, I didn't care as long as I could ride.
    However, I took in water as usual and had no way to pump it out until I became ingenuous.
    Using the nav light switch, I was able to get the bilge pump working by swapping wires.
    So... either my switches are bad or I have a couple fuses out. Is there a fuse box and where? (I assume there must be).
    Also, is it common for those switches to go bad and where can I get new ones.
    Thanks,
    Chris
    My guess would be to make sure you have a good ground to those switches.
