Ok I'm redoing all the wiring in my stereo today and as I was taking everything apart I noticed I only have 4 gauge wire going from my batteries to my battery switch, is this ok or do I need 0 on this??? There is 0 coming off the common on the switch but not sure if I need 0 between battery and switch??
Wire size?
I use 0 for all my battery cables.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I don't think that boat had dual batteries to start withMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I finally found everything I need only took 3 hours because of idiots at oreillys. But what I think happened is the previous owner took the factory battery cable and put it on the common on the switch and just grabbed what ever power cable he could find to go from the batteries to the switch but I got 0/1 gauge wire and picked up a new switch at academy only one I could find in west Houston on a Saturday afternoon because my old perko is melted a little where the common post is so figured one from academy was probably better then that one
