Hey guys. Has to replaced alternator in my MP 5.7. It had a 70amp stock in it and I got a new one from MP that's a 95amp that's a direct swap, sort of. My question is that the bat wire going to the starter is only a 10awg so only rated at 55 amps? Should I replace with a 6 awg to handle the 95amps?
Alternator wire
I would certainly upgrade it if it is only 10ga.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Jedi
- Jul 2010
- 4302
- TN USA
x2 on ChpThril's advice. In fact, I regularly upgrade cabling in charging and starting circuits when replacing them. As an example, jetskis are often a bit undersized on the cables running between the battery, starting solenoid, and starter, making them more sensitive to batteries that have slightly discharged from lack of recent use. I usually bump those up at least one standard gauge (common example: OEM was 6 gauge, replace with 4) on both negative and positive to reduce the IR drop across their length. In your specific case, 10 gauge is way smaller than I'd use for that application. Definitely upgrade.
K. I figured so it will be much easier to just run another 10awg in parallel than replace with a larger asg. That should giver plenty of spare capacity. It just doesn't make much sense that they would undersize it right out of the gate. Maybe they figure no one would drain their battery that far to run the alternator at full capacity.
I would actually lay in a new wire, taking the original out of the circuit, as opposed to laying in a 2nd. That would be 2 ring terminals on the alt stud, which is probably short to start with. You be surprised how little amperage an alt actually puts out, compared to its rated capacity. Takes one hell of a heavy load to get one rev'd up to putting out a high amperage. A 3ft length is 10ga is probably sufficient, for a 70A alt.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Jedi
- Jul 2010
- 4302
- TN USA
x2 again on ChpThril's comments. Don't run two wires, for a lot of reasons. The "weakest link" in any cable connection is the terminals at the end, and running two in parallel doubles their number.
Originally posted by wired1236 View PostHey guys. Has to replaced alternator in my MP 5.7. It had a 70amp stock in it and I got a new one from MP that's a 95amp that's a direct swap, sort of. My question is that the bat wire going to the starter is only a 10awg so only rated at 55 amps? Should I replace with a 6 awg to handle the 95amps?
Hope this helps and doesn't confuse.
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Since the alternator doesn't power the starter, they must be using the alternator or starter as a convenient connection point. So... how does the battery connect to the starter? Does it have its own (hopefully heavier) cable going to the starter? Trying to understand the current flow here.
Whatever the answer to the above question, you should still follow the advice here and beef up those cables. But I would like to know how the battery connects to the starter/solenoid.
WAB,
Its very common on many boat engines with single battery, for the main B+ to connect to the starter B+ post, as well as the alternator's output cable and helm B+ feed. His main B+ and B- are likely 2/0ga. No need to upgrade these.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Jedi
- Jul 2010
- 4302
- TN USA
That's what I expected - that the starter is being used as a convenient connection point. Hope you're right about the battery cable gauge (that's why I asked the question). Interested to hear what he reports.
Thanks!
