We have a 2001 Tige 22V. Its been an awesome boat, but recently we ran into some issues with our Taps system. The Taps system will work great for some period of time and then it will decide to act up and not function. We found that the 20 amp fuse under the dash will be blown when the Taps stops working. We will replace the fuse and the Taps will work again until the fuse blows again. The problem is occurring more frequently as time progresses. I tried checking the ground and it appears to be in good shape.
From what I've read a bad ground can cause this problem or a bad relay can be the issue. I was wondering if anyone had any advice on how to fix the problem and what they would recommend doing. Any help is appreciated since I am not electrically inclined.
