I’m a fairly new Tige boat owner and I’m having a problem with my Tachometer. All the sudden it won’t stop beeping. I got the boat (2002 Tige 2100v limited) a little over a year ago, and enjoyed a problem free summer last year boating with my wife, kids and friends. Even though it’s old it’s in excellent condition. This spring I upgraded the stereo, replacing the original Clarion and the 2 remotes with a Kenwood receiver and 2 remotes, one in the dash and one on the transom. Now when start the boat, the tack starts beeping and won’t stop unless I hold down the “M” (menu) button. The tach (Faria Commander) works (displays the RPM) when the engine is running, and also correctly displays the air and water temp on digital readout on the tach. However the engine hours appears to reset to zero each time I turn the key on. I took the boat to a local boat shop, and he replaced the water pump impeller (had not been done in a while) and hooked the engine up to a computer and did not find any fault codes or problems. The engine (MerCruiser 350 Towsport Mag MPI) runs fines. The mechanic gave up and told me to call Tige. I looked under the dash to see if I could find any wires that I might have knocked lose when installing the new remote for the stereo (or any other obvious problems) but everything looks OK to me. Any ideas what to look for or what to tell the next shop I take it to as a place to start? Thanks very much for any help or ideas!
New Tige owner needs help
The alarm sounder is typically tied to engine management and depth, and not necessarily the function of the tach solely. Did you hook up the new helm remote's illumination wires?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Welcome to the site! I'm not much help, but wanted to get that in there. Maybe try Faria Instruments?
http://faria-instruments.com/index-marine.php
Customer Service: Call: 800.473.2742Mike Allen, Tigé owner since 1997
Tach problem
Originally posted by chpthril View PostThe alarm sounder is typically tied to engine management and depth, and not necessarily the function of the tach solely. Did you hook up the new helm remote's illumination wires?
As long as those unused illumination wires are taped off and not contacting anything, they are not an issue, nor are they linked to your current issue. Is the depth's shallow setting possibly set too deep? Having the Faria hour meter reset is not uncommon, but having it reset each time out, is odd.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
No the depth sounder is definitely set to zero, which means the alarm is off. In any case, the depth sounder is in the speedo, not the tach, and it's definitely the tach that is beeping. Thanks for your help, I'm starting to think I have have somehow shorted out when I disconnected the old remote, and now the tach is bad.
Well, it was definitely the tach. I disconnected it and pulled it out of the dash and no more beeping. Also, no more engine RPM display (except on the Perfect Pass) and no more air/water temp either - and a big hole in the dash. The strange thing is, per the manual, the only alarm in the tach is for low fuel level, and that's only if you have the fuel flow/fuel level option, instead of the air/water temp. I had water/air temp. Does anyone have any suggestions on how to get the gauge tested and/or fixed (assuming it's the gauge and wiring gone bad). I'm sure it's too old to replace, but would Faria fix a 12 year old tach? Thanks!
Different boats, but maybe an old thread might help?
http://www.tigeowners.com/forum/show...ght=tach+reset
http://www.tigeowners.com/forum/show...ght=tach+resetMike Allen, Tigé owner since 1997
Originally posted by TeamAllen View PostDifferent boats, but maybe an old thread might help?
Sounds like a good plan. The one post says $145. It seems like you could buy a whole new gauge for that?
I found some info on their repair site. Possible 4 week wait? https://faria-instruments.com/forms/?form=new
Before, I bought some Faria gauges from http://www.boatersland.com/faria.htmlMike Allen, Tigé owner since 1997
Originally posted by TeamAllen View PostSounds like a good plan. The one post says $145. It seems like you could buy a whole new gauge for that?
