I just got a 2001 2100v and got it in the water. it will stay in the water all season. when i closed up the boat Saturday night the radio was off and all switches on the dash were off. There was a back-lit switch for the floor lights which was illuminated. So I I switched the battery switch to 1 thinking that may drain them. Came back in the morning and the boat wouldn't start. I also noticed that the amps were powered on even with the headunit off. Because the boat is in the water I need the bilge pump powered just in case, so I can't just switch the batteries to off.
so I have 3 questions for you guys:
How do I cut off the backlite dash button?
Is there a remote out on the clarion head unit to have the amps go on and off with the headunit?
Is there any other systems that stay on besides the bilge pump with everything off?
