So I unwrapped the boat today and gave it a good cleaning in the driveway for the start of the season. I flipped the battery switch from the off position (where it had been all winter while wrapped up) to the on position. I put the key in the ignition and gave it a click to the right. Dash and Tige Tough powered up perfect and I could navigate through all the menu's with no problem. As I played with the Tige Touch I realized the blower never came on and the head unit for the stereo never turned on. I went to the audio menu in Tige Touch to turn on stereo and change sources and no go. I went directly to the head unit to turn it on and no go.
I turned the battery switch to combined and boom.... blower turned on and stereo was jamming. With the key turned to the right I should have had auto blower and stereo function with battery switch in just the "ON" position correct?
I wouldn't imagine the battery was bad cause it powered everything else up fine?
Also.... that annoying low voltage screen kept coming on when I had the battery switch in the "COMBINED" position. From my recollection last year the low voltage screen only appeared if I had the key to the left, and I could just have the key clicked to the right and the battery in the "ON" position and everything worked.
Any thoughts guys?
Any thoughts guys?
