Went out the other day and my rz2 started fine and tige touch lit up and the stereo worked, but blower, bilge, ballast, etc all dead. All fuses in box ok.
Did I blow terminal fuse?
did the blower bilge and ballast drain pump work via the manual switches under the helm
