Two amps, head unit, remote and ipod interface all running off of one battery. One stinger 200 amp isolator. Once I turn the battery on either ACC or ON there is a horrible buzz coming through the tower speakers (amp #1) and I suspect it would be there on the sub (amp #2) but you can't hear anything until you turn the key off and then both amps put out a single "pop". Turning the volume down does not help. I didn't have this problem until I hooked up the isolator. Why just the amps? The speakers running off of the head unit are unaffected. Would a distribution block help me out? Is the isolator hooked up wrong? The turn on wire is linked to the ACC power to the deck. The ground is running to battery #2 (all stereo).
