Tige touch not saving data
    I have a 2013 Z1 that is having issues with the Tige Touch. when I save the ballast set times in setup they will default back after the boat sits overnight or even shorter periods. I have also made changes in a few other settings and they default back too. The weird thing is the info I saved in Tige you seems to be saving. Is there a memory battery for this system that can be replaced?
    Talk to Lance at Heinen's there was an update to the touch and you need to make sure you have the most current update. There are threads about it on here and i remember some of the issue was losing data.
      Mine is the same. Going to try the update this weekend.
      2016 Tige Z3, 2014 Tige Z3
