Ok so here are the symptoms.... 2005 22v, Marine Power, Single Batt system
1. Alarm/Warning sound starts as soon as I switch the perko to on without key in ignition
2. Alarm/Warning sound continues in all ignition switch positions but sometimes will randomly turn off
3. Moving key to any switch position will set alarm off which intermittantly continues for up to a minute after key/off removed
4. Stereo will not turn on
Any help is appreciated, I even unhooked all aux leads from the battery and tested it again, same situation and nothing in the electrical system was changed over the winter and everything worked fine. I checked all of the connections under the dash and all of the fuses I could find. If I had a wiring diagram it might make it semi possible to trace the faulty connection but as of this moment I was thinking of swapping a new ignition switch in first.
HELP!!
Oh yeah, I call it the FML ALARM because as soon as it went off today that was the first thing through my mind....
HELP!!
![EEK!](https://www.tigeowners.com/core/images/smilies/eek.gif)
![Confused](https://www.tigeowners.com/core/images/smilies/confused.gif)
