Changing out the LED's in 2012 Z3
    I am wanting to change out the 1" courtesy lights in my Tige Z3 with something other than the plan white. I was thinking Blue. Has anyone done this before if so what did you guys find that worked? I am worried about the finding something that will cover the big hole drilled into the fiberglass.
    I bought side marker lights and changed mine to red LEDs from the factory purple.
    Tige, it's a way of life!
      Oh nice. Did they cover up the hole nicely. Also do you remember where you got them? Thanks
        If the OEM ones can be dissembled, then I would look into just replacing the white bulb to what ever color you want.
          Unfortunately you cant just take the bulb and replace it. That was my thoughts at first but it all one piece.
            I was contemplating doing the same thing on my boat...I came across these online. Do you think the 11mm or 16mm would be a direct replacement? They are waterproof.....
            http://www.oznium.com/led-bolt
