I recently bought a 2010 RZ2. When I bought it in Dec the guy put two new batteries in it. Couple of weeks ago I went to turn on stereo and nothing. Took it in and they said the cranking battery had gone bad, put a new one in and it started fine. I took it home and turned the switch off. Took it to the lake this weekend and it started, but was a little weak. Kept getting a low voltage warning the whole time I was on the water, so I never turned it off. I watched the voltage meter the whole time and it slowly went from 11.6 to 11.2. I ran the stereo the whole time and played with the ballast for 15 mins or so with the engine running. I was expecting the engine to charge it up a little as long as I ran it (about an hour), but that didn't happen. After I got it on the trailer, I turned it off and recranked, it started but was weak.
Everytime I put it away I turn the isolator switch off and that turns everything off from both batteries, but it seems I'm still getting some drain from somewhere. Any ideas?
Also am I expecting too much out of the alternator or could there be a problem there too?
Thanks for the help.
