I know that this has been covered extensively and I appreciate everyone's input on this already. I am almost ready to add a second battery using chp's diagram but have two remaining questions. I have an 06 20v and the alternator cable goes to the starter and stops there.
1. Should I disconnect this and continue it to the Blue Sea ACR that I purchased or keep it connected and run a new cable from the alternator to the ACR?
2. Disconnect it and cap it there and run a separate cable from the alternator to the ACR?
3. What size cable should I use for the alternator cable?
4. From everything I remember reading I should use 2/0 for the other cables between batteries, switch and ACR. Is this correct?
Thank you for your expertise on this. I am just learning as I go and this site has been a huge help.
Lance
Lance
