Broken Transducer(HELP)
    Came in from trip to lake today and found i had ripped my transducer loose from it's mounting bracket. Looks to me like it's going to have to be replaced, not able to repair. can anyone lead me in the right direction for part's. i am unable to find part's for Tige Boats online.
    2001 21v limited Edition
    Pictures please. My transducer is glued to the hull inside. Where is yours located and what brand of depth finder do you have?
      Just replaced mine ordered it from for $25. Double check which one you have, there is a tag on the cable under the helm usually
      http://www.oempartsllc.com/depthfinder-2-1-1.aspx
        Thanks, Laser and 4WB. for the response after checking the one that 4 WB just ordered is the same one i need. Man those TIGE owners never let u down!!!!!!!!!! Not to mention we are all 3 from Texas, HOOK'EM HORNS
          Hook em, my fellow Texan
            Be sure to use marine grade silicon to seal up the hole the wire goes through into the boat and seal it from both sides
