2007 20i electrical problems
    We disconnected the starboard battery to access the TAPS motor and after reconnecting the battery none of the accessories have power. The motor and dashboard function but the blower, TAPS, stereo, heater, lights, etc. have no power. There are no breakers tripped under the dash. Any suggestions for what we are missing? Thanks.
    Dig around for a rogue cable end thats gone MIA.
      Also check to make sure all the wires you disconnected from the battery are plugged back up. I missed one wire when I hooked my battery back up and made all kind of stuff not work!
        Check your cable terminals, mine negative broke at the sauhgtered end to the alternator, took hours to figure out!
          There are 3 or four cables to the positive side (I cant remember how many), but as Mike said... look for the rogue cable. It's probably a #8 with a 5/16" ring connector.
          So this monkey walks into a bar...
