Hi folks,
I have a 2009 rz2 with two batteries and a cutoff switch that cuts out the starting battery only. There is a big yellow warning plate that states I need to disconnect the battery before charging or there will be damage to the electronics. I am curious if anyone knows what they are concerned about damaging and how I can easily go about charging my accessories battery. Since the stereo and pretty much everything else run from that battery it frequently gets run down . I have a charger and power at my dock that I could easily use to keep it maintained. I'm just concerned about doing some kind of damage.
Thanks !!
Thanks !!
