New to the forum! Just purchased a 2000 21v last saturday
First v drive that i have owned and im super pumped!! The taps is not working on it. The owner that i bought it from installed a new pump but could not figure it out. So i am following the wiring and found 3 wires from the Taps not even hooked up?? There is a green wire from the pump running up to the front...unhooked, a black wire running to front....unhooked, and a green wire(not from pump but from the tab area) unhooked. Im guessing the green from the tab area is for the gage can some one tell me which wires go where??
Also there is two black wires coming off the relay block (one from each relay ) not hooked up Any help would be greatly appreciated
![Rockin](https://www.tigeowners.com/core/images/smilies/headbang.gif)
![Bowdon](https://www.tigeowners.com/core/images/smilies/bowdown.gif.pagespeed.ce.PKqybR2Dbe.gif)
