I'm quite familiar with engines, but this one has me stumped. I have read all of the threads on limp mode, but this one is different...
I just bought a 2006 Tige 22i with the 5.7L 340HP Vortec engine. ECU model is TMD1-160G1 403-000078. It appears I have an MEFI 4 system.
The alarm sounds (continuous) on iginition start up and then stops. All gauges work, except for the speedometer (possible the transducer? All gauge readings are within range.
The Problem:
The engine starts every time, and runs fine at idle. I can engage the transmission, and slowly throttle up to ~2500rpm, where the engine goes into limp mode and throttles b1ack to idle. The throttle will not increase again, until I turn off the ignition and start the boat again. If I put the boat in neutral, I can throttle up slowly to rev limiter ~5200rpm. If I throttle up quickly in either drive or neutral, it goes into Limp mode. Same results in forward or reverse. There is no loss in boat power, until limp mode.
I do have the dual battery system. 1 is a brand new battery, the other older one has been charged and load tested at a parts store.
I do not hear any alarms at all while limp mode is engaged.
No thread on here describes how to isolate the two batteries to prevent limp mode? I can at least start there. Any other suggestions, all are appreciated.
The Problem:
