Well - I found the gremlin. Not sure if the battery was bad or if it was the fact the negative cable was not tight around the post - nonetheless thanks to the generous Costco return policy on a new battery and making sure all the terminals were tight all is fixed. Intresting enough I just replaced both batteries in April - anyone have any issues with the Costco marine hybrid battery (e.g. Deep Cycle/Cranking) ?
I believe the motion in the boat caused the negative terminal to loose connectivity and turn the radio off - dam boat
! Thanks for all the advise!
