Just bought this 2000 21V. Have gone through the electrical replacing bilge, blower, new stereo and a couple lights, everything works fine. I wanted to have the engine serviced so took it to the local Tige dealer(small timer) and they go through everything to make sure it works. They call and say I have no power to anything from the dash - nothing works and say they have it isolated to the 2 modules on the dash where you turn the various components on/off. Now I am really upset as it all worked before they started on it and now the good part. If it is in fact these module units, they said it was $695 for a new one but Tige doesn't make them any more so to get a replacement, they have to run a special assembly to make this unit and there is no time frame on it 3 - 6 weeks or longer.
I am going to check for a loose connection when I get the boat home this PM but if I can't find anything, what are my options? Any big dealers out there that might have this part? Any help or ideas would be greatly appreciated.
Frustrated in MN
Frustrated in MN
