My batteries seem to be gradually losing charge even while not being heavily strained for very long periods without the engine on. This is indicated by the boat being increasing difficult to turn over. It still works first try, but isnt turning over as quickly.
My stereo which consists of 6 interior speakers, 2 ktm6's, and a 10" woofer are right around the 1000 watt mark.
My batteries are a Deka Marine Master DP 24 and 24M5. They're stats are attached in a picture. I didn't purchase the batteries and am unsure if this is the optimal setup, but unless there is something wrong with them per se, I would rather not replace them until they give out.
1. What brand and models do you guys suggest? From my research, Guest and Pro Mariner have been the most popular, but I like the Guest chargers in that they are less expensive and come with a 12v male plug, which I would have to buy and install for the Pro Mariner.
2. I would want to get a 2 bank charger and switch to my Perko to the "off" positon, correct?
3. What amp charger should I get? I only go out at most once a day for 2 hours at a time during which the engine is running 75% of the time, so the batteries shouldn't get too depleted each time out and can be plugged in the rest of the time.
