stalling 08 Z1 and loose wire some where
    Hi everyone just got my 08 Z1 5.7 multiport vortex starts ,idles stalls ,stalls while under throttle also. crank it over for a bit may start may not.
    Also had it so it would not crank over till i fiddled around down by the starter and then it started, happened 2 -3 times
    the stalling and not starting is a real problem thanks
    Sounds like one of the problems could possibly be bad gas, or have you had it out already with no problems?
      it had a quarter tank and i filled it up with fresh fuel I am going to change the fuel water seperator filter
