What is the typical voltage I should be getting under power from my alternator? I am only getting 12.9-13.4 when the boat is under power. Seems low. Just wondering if my alternator is going out or weak. Seems like it should be 14-14.4 when going.
2008 RZ2 Alternator voltage
Is this measured right off the back of the alt? At the battery or the helm gauge display?
Before I panic, id get a volt meter and take a measurement right off the large post of the alternator. If good, move to the battery and keep moving toward the helm until you find where the voltage drops.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
- 1 like
