OBDII Connector location
    I wrote Tige' Customer Service Manager Justin Herring the following:
    “We bought a used 2005 Tige' 24v Riders Edition with a Marine Power 5.7 Vortec engine. We are having issues with it sometimes not throttling up and having to shut it off and then starting it back up. I am wondering if someone could tell me where the OBDII connector is located so I can put my tester on it? Thank You!”
    His reply:
    If I recall correctly, it was on the starboard side by the fuse panel. Had a cap that acted as a holder for it.
    I looked all over the boat for a fuse panel but could not locate one on the Starboard or port side. Does anyone know where either the fuse panel or the OBDII connector is located?
    Thank you for your time!
