***UPDATE***
I opened up the fuse block behind the front passenger seat and looked at all the fuses. There is a 25 amp fuse thats for the Alpha tower. It was blown. Replaced the fuse and all good again!
_________________________________________________
Went to the lake yesterday and put up the Alpha tower on our 2017 RZX2 without any issues. After cleaning the boat we tried to lower the tower and it won't move. It's not a battery issue. We have two new batteries.
Tried to replace the circuit breaker back by the red key inside the ballast compartment and no luck.
Thoughts on what else it might be? Is there a fuse in the fuse block for the Alpha tower? Not sure what else could be the issue.
I know I can lower it manually by using an allen wrench but I'm trying to avoid having to do this.
