We have a 2013 Tige RZ4 and are having issues with the Touch Screen. It was already a little delaminated when we purchased the boat earlier this year, but it still worked. While using the boat this past week, we shut the boat off and when we turned it back on, the screen would show lit up, but with verticle lines through it. We could not see any of the touchscreen buttons at all. We talked to a rep at Tige and they suggested we replace the RCA cable. We did that, and no changes. We can remove the cable altogether and the screen looks the same either way. Is this a screen issue? or could this be the actual computer? Any tips or advice would be welcomed!
2013 Tige RZ4 Screen/PC
We have a 2013 Tige RZ4 and are having issues with the Touch Screen. It was already a little delaminated when we purchased the boat earlier this year, but it still worked. While using the boat this past week, we shut the boat off and when we turned it back on, the screen would show lit up, but with verticle lines through it. We could not see any of the touchscreen buttons at all. We talked to a rep at Tige and they suggested we replace the RCA cable. We did that, and no changes. We can remove the cable altogether and the screen looks the same either way. Is this a screen issue? or could this be the actual computer? Any tips or advice would be welcomed!Tags: None
