2009 22ve. Trying to diagnose an acceleration issue. It appears to occur at a similar throttle position and the boat drops all acceleration completely. I changed out coil, ignition module, and cap and rotor. There are no engine codes and the boat doesn't appear to be missing. Once the throttle gets past that point in the throttle, the boat seems to run fine. Thinking it is a bad pedal (throttle) position sensor. Haven't ruled out crank position sensor or bad fuel but those seem less likely to me. Plugs and wires are relatively new and look good. Hoping for help. Thanks!
Throttle Hesitation
