Hi everyone, I am new to the Tige brand and the Ford power plant. Thanks to this forum I have learned a lot. I recently purchased a not running 2018 RZX2. The primary issue was bad fuel pumps. I got that taken care of and fired it up for the first time this weekend.
After letting it run for 5 minutes I shut it off and reviewed engine codes. 9 codes were presented I will get into those later. The root cause of a few of them seems to be poor grounds.
I cleaned up the ground from the battery to the back of the block, I cannot seem to find any others. Can anyone tell me where the primary ground locations are on this boat?
2nd there is a white single wire down by the starter that is not connected to anything. I assume it should attach to one of the studs on the starter solenoid.
thanks in advance for your help.
