I hope I just a house battery issue with it not charging. Memorial day weekend my screen went dead. Ever since then I thought my screen was out. Then I saw another post about a screen issue and dead house battery. I checked and my house battery was dead. House battery voltage was 1.09 and the start battery was 12.58. I installed a new alternator not long ago and I wonder if it is even working. I am very positive my house battery is not charging.
House battery not chargring
Fire the engine up and put a meter on the house posts and see what you read v's the main. The rotate switch to the 4 oclock COMBINE position and measure again. If you get alternator voltage in COMBINE and not in ON, then its likely the voltage relay has failed. or there is a wire or cable disconnected.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by JaredW-00 View PostWhen I switch from on position to both the house battery goes from 12.47 volts to 12.51 volts
I tested the switch. Guess I will get my original oneMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
