Hi, I have a 2003 24v Limited. I'm purchasing a trickle charger for the off-season to keep both batteries charged up -The boat has a regular type of battery switch that has "off", "batt 1", "batt 2" or "combined" positions - is it safe to charge the batteries one at a time while the battery isolator switch is set to "off", or is it safer to disconnect all cables from the positive terminal of each battery? Thanks
battery charging
Switch OFF
Get a dual bank marine onboard multi-stage smart charger. Charges both banks as needed and sont have to worry about over charging from a trickle charger.
Thanks Mike! I'm in New Zealand and there's a store here selling this: https://www.marine-deals.co.nz/smart...a-2-bank-au-nz.
Would that get connected direct to the battery terminals, or to the battery isolator switch?
