heater and Bilge wont turn on though TT
    My bilge will turn on automatically but I cannot turn it on though the tige touch. I also have the same issue with the heater. the heater works if I jump the power to it but will not turn on though the TT. any recommendations? I am starting to think its the medallion unit
    Have you checked the fuses in the long black box behind the kick panel?? Have you swapped the fuse to the blank slot next to said fuses for the circuits you're having issues with??
      yes, thank you. after some further investigating I found some blow fuses everything is working now
