21zx 2021 follows music
    I have a 2021 21 zx with the full rgb package and I would like to know if I can sync the rgb with the music to go full party mode? LOL
    I saw other tigé boats being able to do that but can’t find the way.
    I can switch from solid, pulse and spectrum but none of these effects follows the music.
    Correct me if I’m wrong but I’m pretty sure only the older models with the wetsounds rgb remote could do that.
      I saw a 2018 z3 with it. does the 2018 line comes with the remote from wetsound?
        2018 has the remote feature.
          I do not know what controller a 2021 is using, as it seems Tige has made the move to the ITC controller, but both the ITC Wet Sounds/Shadow caster 4-Zone RGB controller have a 3.5MM audio input.
          https://www.itc-rv.com/wp-content/up...nstall-Ins.pdf
          https://firebasestorage.googleapis.c...8-dd3623e5c964
          The previous Wet Sounds RF RGB with wireless remote also had audio input.
            ok thank you. but is there a way to add this option ?
              I dont follow?
                ^^this.
                pacho21 you would need to swap the current controller to one of these
                https://www.crutchfield.com/S-EqbaiL...kaAnGwEALw_wcB
                You would lose a lot of your touch screen function tho, if not all as the newer controllers are on the CAN network. This controller was simply supplied 12v from a PDM to turn it on and that was it
