R21 Water temp gauge stopped working, Depth works fine
    On my 2018 R21, water temp started reading -20 but depth still works fine. Worked fine for first 2 years. Wiring or biducer? How do I check Biducer to see if it is bad?
    I've changed enough of them to say the Biducer is just bad...armchair guess tho. It communicates via can so if it was a wiring issue your depth would be reading 999.9 as well.
