Diagnostics port for 2009 RZ2
    Diagnostic tool for 2008 PCM EX343?
    do these not use OBD2 type diagnostics? I can’t find a port to plug in to
    2009 RZ2, factory ballast, 260 hours
    Nope, OBDII is a fed standardized diagnostic protocol for passenger/light duty street vehicle. Boats use a MEFI# system and does change over the years. It does have a diagnostic port and codes and data, just not OBDII.
      Is this what I need?
      https://www.rinda.com/acro/codemate.pdf
      Is there something else you recommend?
        https://www.rinda.com/marine/diacommarine.htm
        This is what most people use.
