Any suggestions on a dual battery kit for 2001 2100v with 350 mag? planning on setting that up before the season starts but don't quite trust my electrical abilities. Would like to find a straight forward isolation kit. Just want it to run my speakers and other accessories. Sorry is this is a repeat question. I couldn't find another similar thread.
Dual battery setup for 2001 2100v w/ 350 mag
As far as a "kit", they really dont exist, as its mostly a custom install. You kind of have to build it ( or have it assembled for you) as it requires custom length cables with battery lugs, etc. There are sources that can provide the tech support, diagrams and necessary components, taking a lot of the guess work out of it.
There are two basic/common setups that will work for you. A traditional OFF/1/1+2/2 switch or the Dual Circuit Plus switch and ACR.
The traditional switch setup is simple to configure, easy to use and effective. Only real downside is thats it 100% manual.
The DCP/ACR setup is more complex on the frontend to wire up, but its mostly automated once you are on the boat.
Both allow for turning all the non-essential loads off when the boat is not in use, and for one bank to be used as house bank the other back as the main cranking bank.
- 1 like
