I just purchased a 2013 Z3 and I'm having a few issues. The previous owner did a number on the electrical system in the boat. I need a few pieces of information to get everything working correctly again.
1) The boat came with amplifiers that were not working, so i wired in new amplifiers. those are working fine, but the radio power was supplied by the amplifier power wires and a manual switch. I can't find the power wires for the radio. I am a fan of keeping things as close to stock as possible, so i'll run new wires from whatever fuse block is supposed to power the radio, but where is that fuse/breaker?. There is a switchboard of some kind under the helm with 20? switches, but i didn't see any radio/audio/head unit/receiver labels on it.
a) the screen doesn't work on the transom remote. the transom remote buttons still control the radio. the touch screen and panel to the right of it don't control the radio. I ordered a new control module, but I'm not sure if the problem could be the head unit or cables.
2) There are several loose wires behind the radio, one white, two blue with white spiral stripe, and one black wire. The black wire is not a ground and I can't make any of the wires hot with switches the rest of the blue with white spiral stripe wires in the boat seem to be for lighting, but nothing happens when I turn on all of the lights. are some of these wires the radio power? am i missing a fuse panel? (I have messed around a little bit at the helm, but haven't found anything)
3) When the boat power is on, one of the tower downlights is on, all the time. I think someone was there before because I can't get the other light to come on at all, and the "tower" light button turns on the docking lights on the tower. nothing happens when i turn on the "docking" lights, nothing happens when I push the button for tower color. It seems like crossed wires at the switch or something, are the tower lights are plugged into the wrong thing and the docking lights plugged into the tower light switch? What do I check first? how do i know if my boat has the RGB controller?
