Anybody out there have a 2003 22i Type R - Wiring Diagram? I'm having some electrical problems and want the wiring diagram to help troubleshoot.
There is power to the dash switches for blower, bilge, lights, ballasts, etc., but no power to gauges or anything when key inserted and turned to either first position or to start position. There is also power to the engine and the trim works. After spending some time checking fuses and continuity to all but the main wiring harness running up the dash (because it then splits into multiple harnesses looking like a bird's nest), I am thinking I'll replace the ignition switch and see if that does the trick.
We fixed a gauge issue on an 05 V and it was the ground on the back of the volt meter. That gauge got the ground first off the BUS and it was loose.
Grab a $20 meter from harbor freight. It will pay for itself in the first hour.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I am replacing the ignition switch from the former owners butchered push button system. I
bought a Sierra 3 position Off On Start switch.
The wires that appear to have been wired to the old switch are
RED
PURPLE (fused)
YELLOW/RED (fused)
BLUE
BLACK
My guess is on the actual ignition switch I will be using
RED
PURPLE
YELLOW/RED
BLUE
but two of these go together?
Im thinking on the back of the switch
B - RED for constant 12v
S - YELLOW/RED - Starter solenoid
I - BLUE AND PURPLE - Ignition circuit - so this has 12v power when boat is running or key is turned on.
Make sense?
Anyone have any pics of their ignition switch?
